The rear suspension is on blocks and feels a little firm. Is there a brand that is softer feeling than others? And what is the advantage to outing on leafs with the suspension build in vs blocks under the leafs?
Lost of things contribute to the ride feel. The two obvious pieces are the springs and the shocks.
To really tell if the springs are what's creating the firm ride, disconnect the rear shocks and go for a short ride. If the ride is still too firm, then consider replacing the springs.
With a stiff spring, lift blocks aren't too bad. But lift blocks contribute to spring wrap. For a street truck, that may not be too impactive. But for off-roading spring wrap can really be an issue, creating several different problems.
Most of the springs for a 3 1/2" lift will be 11 leaf packs. These are made for the off-roader looking for some flex from the suspension. A side benefit for the street driver is they are much softer than the stock springs. But then, since most things are a compromise, this will affect handing with increased body roll. You might investigate BC Broncos rear leaf springs. Chuck had them designed with 9 leafs. Probably a better compromise between handling and ride.
Of course, then, don't forget the shocks...
