broncaholic
- Aug 17, 2009
- 280
Currently getting my stuff together for the Explorer intake swap and have been reading up on the TB/MAF size for torque & HP. I recieved a 70MM TB with the intake and have a 70MM MAF sitting on my shelf. Is this overkill and will it affect my lower RPM torque? Should I use my stock 60MM TB and MAF? I am currently running an Edelbrock Rollin' Thunder Performer-Plus Hydraulic Roller with the following specs.,
#3722
ENGINE: FORD 5.0L V8
RPM RANGE: Idle-5500
Duration at 0.006" Lift: Intake: 282° Exhaust: 282°
Duration at 0.050" Lift: Intake: 220° Exhaust: 220°
Lift at Cam: Intake: 0.311" Exhaust: 0.311"
Lift at Valve: Intake: 0.498" Exhaust: 0.498"
Timing at 0.050" lift: Open Close
Intake: 0° ATDC 40° ABDC
Exhaust: 40° BBDC 0° BTDC
Centerlines: Lobe Separation - 110° Intake Centerline - 110°
Note: May use original hyd. roller lifters. For mass-air engines only.
I may junk the cam and go back to my stock roller cam if any combo is significantly better than the other. Any advise is appreciated.
Thanks.
#3722
Thanks.
