- Aug 27, 2001
- 5,151
Was pulling out yesterday in the stock '77 and the rear end went BANG. It's a 3 speed and I was dead in the water. Locked the front hubs and went 4 wheel drive and limped her home. Figured I'd broken a u joint in the driveshaft. That wasn't it. Well the rear driveshaft/pinion spins when I put it in gear and let the clutch out. I jacked the rear up on jack stands and spun one wheel , the other spins the opposite way like normal with open diff. While on jack stands, I even started it and ran it and the wheels spin when I let out the clutch like normal. But... When I let the jack/ jack stands down, let the clutch out, it barely tries to move and makes a slight grinding noise. Driveshaft still spinning. Any ideas why there's power to the rear end.... but No Go?
Thanks,
Blue71
Thanks,
Blue71
