Big 9" problem, 77 won't move
Blue71
Blue71
Blue71, your description sounded familiar. I had to pull out my maintenance records book. Back in '93 our car had 137,075 miles and while on my way to a salmon fishing in Oregon, the car broke down. The driveline would spin without moving the car. It made a sort of ratcheting sound. I was only 150 miles from Toms Bronco in Medford. This was my first experience with them and they talked me through the diagnosis and repair. They asked me if it was a Trac-Loc. Turns out that Trac-Loc was a cheesy design that uses only 1/4" of that axle to drive the whole carrier. The open differential however, uses a full inch of spline.
I ended up replacing the driver side axle and I also replaced the differential with a used open one they had in stock. The stripped axle had damaged the splines in the carrier. I made the whole repair in less than two hours.
Well, a good end to this long story...
I caught a great bunch of salmon and made some great new friends.;)
Glad the trip turned out well.....ahhhh Salmon! Got me to thinking so I went out and clean the ankles up and inspected further. Seems that I have a problem very similar if not the same as you Blubuckaroo. The passengers side axle splines are in good shape, however...the passengers side are a bit stripped on the first half inch of it. I'm still thinking I have open diff because tires did spin opposite and I have the I.d. Tag stating 3.50 "9" where if it were locking from the factory it would look like 3 L 50 "9". I know, I know the center section could have been swapped, or a trac loc could have been added, but it's doubtful on a low 55k mile clean truck. Ya never know though. I'm wondering if it also messed up the gears. We will see I guess. Thanks for the story as well:)
Andy
Blue71
Blue71
Blue71
Here are the axle ends.....passengers side
Blue71
Blue71
Drivers side...And here I feel is part of the culprit....first 1/2" is stripped. Do you guys know if further damage is usually done to the inner gears when this happens?
Blue71
Blue71
Poor ole gal!
Blue71
904Bronco
San Martin, CA
I know your pain...
One of the Broncos I work on had the same thing happen. Only 75K on a 77 Bronco.
Daughter backed it out of the driveway, put it in drive and no go.
Pretty sure it was a factory Trac Loc on 3:50 gears.
Needed two axles and spider drive gears
Blue71
Blue71
I know your pain...
That stinks.....that axle is reall chewed up. Did your daughter hear a Bang or anything like I did when it went? Was it just the axle or was anything else damaged inside? Let me know. Thanks,
Andy
Blue71
englewoodcowboy
Lick Creek Restorations
I spoke with Andy on it and think it is the spider gear stripped where it splines to the axle. Depending who he took it too to get looked at, I suggested to him to pull the spiders out and have a look. If he doesn't get it figured out by the weekend I will take a run down and see what it is. He said the splines look good and even on the shafts. Anyone know what the spline specs are? I can mic them when I go down to see if the shafts are still good or not.
broncnaz
Pass side on the trac loc is just a spider gear. The driverside has the spider gear and the splined clutch hub. So if you did have a trac lock its probably very worn out and it wont turn the other axle. Or you have a open diff. and the stripped out spider gear is the only thing that will turn since it has no resistance.
But it does appear thats a trac loc on the pic with the drivers side splines stripped off. as you have a shiny area where the clutch hub teeth contacted it then it appears to have non shiney area then the end where the teeth are missing where the other spider gear would be. It can be hard to say wether or not anything in the diff is damaged. Your going to have to take a good look at it and clean it out. I have a feeling you may not have much damage in the diff. Its very common to see old axleshaft splines twisted up. If anything else was broke I would think the axle shaft splines would have survived.
You can easily tell if you have a trac lock once the chunk is out if the ring gear bolts are recessed then its a trac lock if they are not recessed then you have a open diff or other type of locker.
Id say in any case that drivers side shaft is bad.
Blue71
Blue71
Thanks Broncnaz and the rest of you all for getting me thru this. I feel like the chunk has been out and replaced in its earlier life with a Trac loc. although VIN and axle tag say its Open Diff...it is in fact a Trac Loc. We looked the gears over really well and as Broncnaz suggested...the gears, side gears, spider gears, etc are in good shape. The drivers side axle seemed to be the only culprit, with the exception of a bad u-joint near the yoke at the rear. Not sure if that would have contributed to anything, but I changed it. I got it all back together tonight using a spare 76-77 drivers side axle. Filled it with Lucas tonight (supposed to be good for limited slips ) and drove it about 10 miles. Brought her back...checked for leaks and it's good. Seems good as new again. Thanks Tom,for the phone conversations about this problem. Hopefully this will help others. Seems like it's happened to several of us. Thanks, Blubuckaroo, Bart, weldndmn, Rusty, JW, 904, Glass, etc
Andy
Blue71
904Bronco
San Martin, CA
Andy
Blue71
Glad you are back together again.
No noise heard (or reported), it just did not go when it went into drive. But then... the radio volume was probably up when it happened to her... :D
