Big changes to the trail rig
stout22
stout22
Athens, AL
Same spot from behind
No damage occurred at this spot
fordfan
You can test that revisited rigs ability in the snow this weekend it looks like,,,, Those tires look like they would be great in the white stuff!
Howard2x4x4
Rogers, I am in awe! That revamp that you (and Steve) did on your ride is phenominal, even inspirational. I know you had one of the very best whispering in your ear, but, even so, amazing success! I almost always end up on TAME trail (Trial and mostly error).
Colo77Bronco
Colorado Springs
These recently came out, but I think I'm sticking with 4.88's for my 40's. With a NP205 doubler I should have plenty of gearing. I think your 10r80 will be perfectly fine as well: https://revolutiongear.com/ford-10-...io-37-spline-ring-and-pinion-revolution-gear/
I agree. When i bought my 4.88 I had actually tried to get the last of the Nitro Gear 5.38 that they had for the rear but they sold out and stopped making more. I'm glad that I got the 4.88 now with the lower gearing in my 10r80. My mind was still stuck on compensating for C4 or AOD when I wanted the 5.38.
gclauson
Rig and suspension look great!
Question on your wheels and tires. An earlier post said 17x8 OEM steel wheels with 40" tires. I'm planning to do the same axles and wondering about wheels. I found a set that looks the same as your photos, but the rims are stamped at 17x7.5. Wonder if that is what you have? And are your tires 40x13.50? Any issues with the wheels feeling too narrow for the tires? If they seem good to you, I'll grab the set I found.
TIA!
