I've been thinking about it too, and how many different programs have you tried? Is it possible that you have a defective ECU? I think you said that it ran fine before though, is that correct?
You running an automatic or manual trans? Auto or manual ECU? Jumper position in Ryan's harness?
Pretty much just one, except I have tried different things, such as different spark advances and a C&L MAF. I can get codes out of it, and it seems to output data the right data, so I think the ECU should be fine. I have it hooked up for manual on the A9L.
Is that hole in the front left corner of the lower intake where you have the ACT sensor?
Yes.
Did you verify number 1 TDC was actually where the timing mark and the pointer meet up? So many combos,..
Not to the nth degree, but when putting the timing chain on, everything lined up properly.
Hmm, did you remember to use a 28 oz imbalance flywheel/flexplate to match the 28 oz stock damper?
The rotating assembly was balanced together. When in an upper RPM, I don't have any vibration. I think any shaking is due to the engine generally not running well.
Thanks for the help.
Eric
