Bilstein Shock Valving
kaw550
I installed four Bilstein shocks in the spring. The ride is still pretty harsh. I can feel every crack in the pavement.
I was wondering if I bought the right shocks.
Front is 5100 (F4-BE5-6528-H6)
Rear is 5125 (F4-BE5-6248-H5)
No problem with the fit just the ride.
I assume it has to do with valving and response but I thought they would have smoothed things out a bit.
Can the valving be adjusted?
I have Deaver coils and Toms 11PK leaves.
Heus33
Thats odd - its nearly identical to the setup I ran in my blue bronco (except you have better rear springs).
Are your coils the SuperFlex coils? Your coils and springs determine the stiffness of your ride, the shocks control the 'bounce'.
You can try to elimate the shocks as the issue. Pull the shocks off and take it around the block - see if that helps. If your issues go away then it might be the valving.
kaw550
kaw550
I did pull the shocks a while back. Really soft up front. I have one shock on each corner.
I called where I got them and the manufacturer.
I was told the front are valved at 390/95 and I think the back were 225/70.
I was told that the front is about the same as an xterra but a stock bronco would have been 225/100.
So how does the valving rate ? is 390/95 considered firm?
I think he said a stick bronco came with 225/100.
Devin
Bronco Kineticist
I have 5125's in the rear with 255/70 valving.
I have 7100's up front with 360/80 valving.
Duff front coils, and Duff 11-pack rear springs.
The thing rides like a dream. Strange that you aren't experiencing the same thing.
73stallion
Eugene, OR
395/95 may be a bit firm if you're running stock bumpers and no winch, but shouldn't be that bad. i also have 7100's with 360/80 valving, i'm running a winch and heavy bumper, it still seems a touch soft to me.
JefeAZ
Tucson
Bilstein can revalve them, at least they can on my Cobra Bilsteins. I think they wanted $45/each. Just need to let them know what you want
kaw550
kaw550
I did get them on the phone and was told they could be revalved. They suggested I talk to someone who is out of the office until Monday. I was impressed with their customer service.
Any suggestions on what would soften the ride? I tried searching for the specs on other shocks but only came up with the lengths. I did find this chart
http://www.eshocks.com/bil_ORgd.asp?Manf=All#Type
I put the bronco as a mid size SUV. In that category it has 255/70 for the front and rear. Is that too light? I see most recommend 360/80.
Mine is stock with a V8, cage, soft top, 33" tires.
cafyrman
Poway, CA
The Baja 1000 is going on right now, so Bilstein's shock experts are probably in Mexico.
I really don't know a whole heck of a lot about shock valving, but the calculator you're using is likely calibrated to a "modern" mid-size SUV which is likely considerably lighter than a Bronco.
I wasn't aware that 5100's could be reworked. I thought that the 5165 was pretty much where that ability started. But I guess they could take apart the top and do what they wanted.
Are you sure it's the shocks?
