Blasting? Grinding? Prep for "Line-X"
ObscureMachine
Seatbelt Orifice Officer
World Headquarters
I'll be putting together a new plan for building my bronco soon, but I have a question about getting to bare metal on the interior.
Going to have passenger floor pan installed. Then remove all seats but driver's and remove roll cage. Then get rid of the Denno-Liner (evil undercoating / liner / crap that ButtStank did) - by blasting or dipping of scraping of chemically. Then "Line-x" the floor of the entire tub, reinstall seats and new family cage.
1. To get to bare metal, should I media blast? If so, what kind of media?
B. Is it ridiculous to save money and wire brush the entire floor (wire brush on grinder or drill)?
Q. After I get it to bare metal, what should I do (primer? paint?) to get it ready for Line-X?
Thanks! Jim
Contact Line-x directly and find out what they recommend. most liners don't do over bare metal. Most want paint and scuff. I doubt you can sand blast off the old liner it like rubber media will just want to bounce off. If you heat it up and scrape it off the fumes are toxic. A really course wire wheel and a medium speed grinder may be your best friend. For scuffing paint Al's Liner plastic bristle brushes work well but you have to run them fairly slow speed and use a drill motor. A 4-1/2 inch grinder was too fast. Unfortunately it wont push off old liner.
Lunar-tic
Brentsville
I used a heat gun and putty knife about the width of the grooves in the bed to remove the DIY bedliner. Then a wire wheel on the remaining, hard to reach spots. I tried the chemical stripper, but it didn't work as well.
I don't know about Linex, but Rhino Extreme will stick to just about anything.
sykanr0ng
Instead of putting the Line-X on bare metal I would put epoxy primer on first.
Mix some heat and noise insulating ceramic micro-balloons in the epoxy primer.
ObscureMachine
ObscureMachine
World Headquarters
I want this liner that's on it, gone. So I don't know if it will need to go to bare metal or not. If it does, I like the idea of the epoxy paint. How does it get applied?
sykanr0ng
To remove the liner material that is on it now you will be taking it to bare metal or close as makes no difference.
Most likely scraping or wire brush will be needed because liner is meant to be hard to remove.
Most people apply the epoxy primer by spraying, though brushes and rollers work too.
http://classicbroncos.com/forums/showthread.php?t=253131
rguest3
Every LineX job I have had done, MANY OF THEM, the shop did all the prep work and installed their own primer. Which is very hard and tough as nails, then applied the coating.
Lifetime Warranty too.
BronCowie
Old Timer
Vancouver, WA
Contact Line-x directly and find out what they recommend. ...
^^^THIS^^^ is what I did prior to my Raptor application. They were great and told me exactly what I needed to do. 5 years later it is holding up great. I did not go down to bare medal unless absolutely necessary.
Its all in the prep. 95% prep, 5% application time-wise. Good luck Jim!
ObscureMachine
ObscureMachine
World Headquarters
I think there is a lot of sketchiness on the floor in the rear. I know there is Bondow and some fiberglass. So I'm going to blast the entire floor and see what needs to be repaired. Then once it's prepared take it to linex. The line X guy said since it might take a while to get everything done I should use some type of self etching primer that the Line-x can adhere to.
Jamie Chriss
I just got done stripping layers of Bondo and old plastic liner. I used a very agressive large gage wire wheel. I stripped off everthing down to the bare metal, there was allot of pitting from the Bondo holding in moisture. I treated the metal with phoso and I am prepping for epoxy primer. good luck
rydog1130
Once you get to bare metal, make sure its clean, i usually use a combo of tack cloth to pick up any dust then give it a good wipe down with a micro cloth drenched in acetone, then back with the tack to grab any stragglers. The epoxy primer is easy, eastwood has a simple 1:1 mixture. Get yourself the cheap purple gravity fed gun from harbor freight along with an inline moisture filter and spray away. One gallon did my entire truck top to bottom. Once the epoxy was down i used an 80 grit foam sanding block to scuff the bed, those are nice because they are squishy and can get into the grooves of the bed. run your tack cloth only to pick up the dust as acetone will strip the primer, apply your liner
Great job my back and knees hurt just looking at it.
ObscureMachine
ObscureMachine
World Headquarters
I just started poking at different places and found this stuff. Bondo and fiberglass. The roll bar is mounted on top of about 1/4" of fiberglass with bondo under it.
Have you looked at the floor from underneath to see what you are actually up against? You don't want to be stripping the whole floor if your going to be cutting it out and replacing it. Work smarter not harder.
ObscureMachine
ObscureMachine
World Headquarters
That's now my plan for tomorrow. But PO sprayed EVERYTHING underneath with some kind of undercoating. That will be fun
ObscureMachine
ObscureMachine
World Headquarters
Sounds like you need to take the body off the frame and put it on a rotisserie. DoH! :-X ;D
You know, I haven't had time to work on the bronco, so it sat. Now that I have time to work on the bronco, I have no time to do a frame-off, because I have to get certain things done before the rains set in, and before the Mustang is gone.
Now that I have time............. I have no time! Kinda ironic.
This stuff will just make the frame off I do later easier and faster! Yeah, yeah, that's it. Yeah. ;) :p ;D
sprdv1
REBEL
LOL, always how it works man
ObscureMachine
ObscureMachine
World Headquarters
I was hoping I would only have to replace the passenger floor pan. But now I know I'm going to have to replace the seat platform as well, and probably the small sections in front of and behind the rear wheel wells.
Jamie Chriss
I just purchased the entire platform and pans pre welded, I have not put it in but looking at it I would say it will be much easier to replace the whole thing rather than piecce by piece.
