Bleeding brakes...?
WARDOG
Graniteville, CA
I replaced my brake lines and need to bleed the brakes.
Front disk, rear drum.
Should I bleed one before the other?
thegreatjustino
Red Head Grease Monkey
Stockton, CA
You bleed them in order of distance from the master cylinder. Passenger rear first, driver rear second, passenger front third, driver front fourth.
spap
If you get a set of quick bleeders they work really well.
AndyT
X2 on this. Pump til there's a constant stream of fluid. Generally 3 to 4 pumps will suffice for each.
smokinjoe
New Braunfels, TX
Exactly :)
I bought the air/pneumatic brake bleeder from HF a while back, it's awesome, you just place the hose over the bleeder screw and pull the trigger; its actually pretty sweet.
jray
Make sure to keep an eye on the fluid level in the master cylinder. If it gets too low, you'll have to start all over again. Don't ask me how I know.
