Fill the cooling system. Pull the heater hose off at the intake until coolant comes out.
At that point it is full enough to run.
Start the engine with the cap off and run until warmed up, topping off as needed. When it gets warmed up it will want to start spitting some up the neck, put the cap on.
After it cools off, top it off again. Hopefully you have an overflow, put some in there. Drive it some and keep an eye on the overflow. Any last bubbles in the system will burp out over a few trips.
The vacuum fillers are neat. Watch the radiator hoses collapse from the total vacuum in the system. No air at all so only coolant will be in the system. Neat, but for the caveman engineering of the Bronco's cooling system it is a little expensive. If you have other needs, get one. Just the Bronco, there are better things to spend money on.
