76 bronco, Painless Wiring Harnes with LEDs everywhere except the instrument cluster. All have been installed and working for a while.
I was doing a walk around last night checking the lights, blinkers, flashers, etc. All was good until I turned on the flashers. Noticed they were barely working in the rear and not in the front. Turned them off then I had no front / rear blinkers! The flasher switch now activates the front / rear marker lights (no flashing) and the right turn indicator on the cluster (doesn't blink).
Headlights (high/low), Marker Lights (all), and Brake Lights all work.
Where should I start? Thank you!
