Blown Head Gasket?
jarhed1984
Homosassa, Fl
So four years ago I installed a 5.0 crate motor from Phoenix Engines. It's been pampered like a show dog. Has less than 100 miles in four years. The other day on its weekly chicken wing run it starts running really rough. There are leaks on the exhaust manifolds on cylindes 3 and 4. I just check compressions and they are 1 121, 2 126, 3 112, 4 95
It blew oil out the breather and I see exhaust coming out the rear corner of the valve covers. Where should I start? Is it even possible I have a blown head gasket in under 100 miles?
Thanks for all opinions in advance.
[/URL][/IMG]
Anything is possible of course, but it could be other things as well. Letting it sit so much may be the only reason you're seeing low compression on the one cylinder, and a little low on the other cylinder.
I'd drive it a heck of a lot more first, before tearing into it.
Do you have anti-freeze mix in it, or just water? If just water, it's entirely possible for a head gasket to have corroded through. Doesn't seem likely in such a short time, but it's probably possible.
Valve seals could have deteriorated, but that would usually result in smoke out the tailpipe from oil getting in the cylinders through the intake stems. Eventually it could build up to the point you'd see it coming out the exhaust gaskets, but seems like you'd have to drive it a heck of a lot more for that buildup to occur.
However, on that same theme, because you don't drive it much it may not warm up enough to burn the oil buildup completely out of the exhaust ports either. Which may hasten the buildup.
Oil buildup around the exhaust gaskets can also come from leaking down from the valve covers. This is very common in fact, and may be your issue with any luck. If you run it a few minutes and then can feel some oil buildup on the head between the valve cover and the exhaust manifold, this may be all it is.
Intake manifold gaskets can fail too. Leading to all sorts of issues, like oil leaks, vacuum leaks, and coolant leaks. Not to mention rough running.
Do you run a full PCV system? If not, you should install one without a doubt.
What ignition are you running?
Carbureted or EFI?
Got some more pics from under the hood?
Good luck.
J
jarhed1984
Homosassa, Fl
Thanks for your help Paul. I'm running 50/50 antifreeze. I don't see any sign of any. The oil in the valves look pretty normal. I haven't done any block pressure tests. When I took off the valve covers the ones above the leaks were only finger tight so that may explain my leaks. Can loose valve covers make it run squirelly? When this started I had been running it for 20 minutes and was about 4 miles down the road. It hit like fuel starvation, I switched tanks in it seemed better but still missed all the way home.
I never checked the torque on the heads, because only 100 hrs. I"m just running a 600 Edelbrock and a Pertronics Flamethrower distributor.
Thanks again for your help
langester
MASTER OF MADNESS
How old is your fuel? Your first post says installed 4 years ago and you only have 100 hrs run time. Just curious, might be causing your fuel delivery issues.
J
jarhed1984
Homosassa, Fl
I topped it off with Non-E and about four months ago. I replaced the fuel pump with an electronic in front of both tanks. Both tanks were replaced in the rebuild 4 years ago. Carb still seems to want to burn really rich. I didn't change anything from the factory.
Normally a lose rocker cover will not cause the running issues.
In theory yes, because of the PCV system pulling outside air in, would act like a vacuum leak. But the cover would have to be so loose for there to be any noticeable effect that oil would likely be everywhere quickly.
blubuckaroo
Grease Monkey
Ridgefield WA
This could be just a loose or damaged plug wire. You can check them with an ohm meter.
Is there any blowby?
How's the compression on the passenger side?
I'd tighten the covers, and give things a closer look.
