Blueprint Front Accessory Drive?
Almost nothing fits in the front of a Bronco!
Never seen that one (thanks for the link), but I think there have been one or two members here that have bought them. Just don't remember if anyone is actually running theirs yet.
Looks nice, but by the dimensions provided (6+ inches in front of the block) I'd have to say that your pulley and your radiator are going to be really intimate!
Hopefully someone has tried it and can give some insight.
In the meantime, whether it looks cool or not, I think everyone agrees that, barring some kit I've never heard of, the Ford factory Explorer V8 stuff is by far the most compact and efficient of all the accessory drive setups.
A member here sells kits when he has them. Complete and has a very good reputation for supplying all the parts at a fairly reasonable price. Versus going to the junkyard yourself.
Too bad that nobody in the aftermarket has started reproducing them yet. I think it would be a great seller for just about any platform using Windsor style engines.
Nice!
Thanks for the link. I’d like to build something similar for my 400 in the pickup.
Don’t need the size so much, but rather the solid alternator mount and convenience of the serpentine belt in place of the existing 43 v-belts running everywhere!
seanwanlass
seanwanlass
Thanks Paul! I did some research and found out who makes the S-kit for BPE or maybe BPE makes it for CVF racing :unsure:. They are using a GM ALT and GM PSP.
https://www.cvfracing.com/small-blo...sive-wraptor-serpentine-system-stealth-black/
https://blueprintengines.com/collec...ve-full-serpentine-w-alt-ps-wp-brackets-bolts
badandy73
Broncoholic
Seems like there was a thread not too long ago with a guy running the CVF setup, could search it up.
Like others have mentioned, I'd just go with the explorer setup, it's pretty slick and checks a lot boxes.
Yeah, pretty big discussion about the CVF set up. I think he made it work, but it took a lot of determination if I remember.
Or maybe it’s not done yet?
Jaybr
That was me that installed the CVF setup, details in that thread. I don't have the bronco on the road yet but I did get a setup fitted with an electric fan and WH (Ron Davis) coyote radiator. I did have to make a shroud and modify the radiator brackets.
Stock fan fit fine, but couldn't get a clutched fan to fit with enough clearance to be comfortable with it.
