I thought this would be one of the smooth parts of reconstruction, but I should know better by now. I did a frame off restoration and had the complete tub on a rotisserie to do the work. After the frame and tub were ready to meet again, I put them on with a 2.5 suspension lift and a 1 inch body lift. When I tried to put my doors on to line them up properly, I found that the top part of the latch side of the door was pretty opened up. In other words, the opening expanded instead of taco'd.
I should mention that I welded in new floor pans, but I did this when the truck was still together so it would self-fixture. When I shimmed up the rear of the truck to close the gap, it was about 3/4 of an inch needed in order to shrink the gap. This is not going to work for me seeing as this seems excessive. Any advise on possible issues, or a sequence of bolting down the bolts, or anything else that comes to mind is appreciated! Thanks in advance for any input.
More info: Bottom line of door and body is pretty close, hinge side of door seems okay too. WH lift kit was purchased. That is about it!
