- Jun 17, 2004
- 359
When I bought my bronco the body was only secured to the frame with the rear 2 body bolts. The rest were loose and coupling that with a completely rotted floor and broken floor braces, nothing was lined up properly. I’ve gone about bracing the body, finding that the body had spread almost 2”. I’m to the point of installing new floor and am using the dynacorn 1 piece floor. I’ve got it laid in and a single sheet metal screw in the center of the floor pan lined up with the center of the bed. Problem now is the center of the floors don’t line up with the center of the windshield! You can see there is about 1” out to one side. If I shift the floors to line up on Centre the floors are no longer square to the bed. I still have the top on and bolted to the windshield frame trying to keep everything in some semblance of square, but for the life of me I cannot get the floors lined up. I checked the tailgate and also found that the tailgate center is about 1” off the center between the frame rails, but if I shift it I figure everything will shift together and I’ll still be out an inch in the floor boards.
Any words of wisdom would be great to hear!
