So I have a 74 that was a complete mess due to heavy corrosion. I decided to go with a new Throttle Down Kustoms (TDK) frame and began the restoration from the ground up. I have only heard great things about the TDK frames, and was impressed with the absolute attention to detail and craftsmanship when the frame showed up at my home in San Diego. I currently have it leveled in my garage, with the body built from the rear forward from a TBP "Bronco in a box" standard body kit. I took measurements from what remained of my old body and what I could find on the TBP website to construct everything up to the firewall. However I am having quite an issue with the distance from the forward door posts to the core support. The TBP forward posts are not great and required a bit more trimming and massaging to get them to fit. once fitted with the doors hung and gapped and the front fenders installed the core support appears to be about an inch farther forward than the body mount on the TDK frame. Everything is bubble leveled or laser leveled. The hard top is installed for symmetry?
Has anyone had these issues?
