Bolt size for seatbelts
Minderbinder3
I am replacing the lap belts on my ‘66. I don’t have the original bolts that held them to the floor.
Can anybody tell me what size they are? The floor has threaded holes and I can’t find anything in my miscellaneous bucket of bolts to fit correctly.
Minderbinder3
Minderbinder3
Here is a pic
Are you doing a restoration and need correct bolts?
Or just making a driver and need functional bolts?
7/16-20 I think. That should be standard off the shelf 7/16 fine thread bolts. I am also making the assumption that the '66 is the same as the newer ones. Not the normal 7/16-14 coarse thread
Minderbinder3
Minderbinder3
Making a driver. I am pretty sure that it will be fine thread.
I will pick some up at the local hardware store and let you know if they work.
Thanks!
