boring a engine how far
ryansbronco
The place of bronco
generally you have to change positions when you bore your block
Ive heard about getting larger rings and still being able to use stock size pistons
73stallion
Eugene, OR
if you bore it, you're getting new pistons. if your tolerances are good you can HONE it and reuse the same size. but you want no ridge at the top and no hourglass shaped cylinder walls.
B
broncojames
Smelterville ID
there's a local machine shop every one uses but then hes the only one with in 70 miles
guess i bight the bullet and bore it with new pistons or just hone it decisions decisions
Wyflyer
take them the block, they will mic it and determine if the bore is within tolerance for a hone versus a bore.
It has a pre determined tolerance, IE a go/no go size. Until it is measured there is no way to know what it needs.
taylorB
Canton, GA
That's exactly what you want to do. They will be able to tell you exactly what steps you need to take. We on here have no clue what kind of condition your cylinder walls are in.
fordguy
x3 if they are worth their salt they will have the tolerances and can mic it.
