Boring wheels
Ict57
Found a set of 17" dodge steel wheels and planned to bore out the hubs so I can use these (vs the 1987 iroc-z era Americans).
However most machine shops I call won't touch em and I've gotten one bid at $80/wheel.
So to guys who've done this, any suggestions?
maup
When the shop is slow I commandeer the machines at work sometimes, for Bronco...I mean government jobs.
But seriously, sometimes it helps if you know somebody...if you were anywhere near me I could point you to a shop or perhaps do them myself.
Where you located? Maybe someone will know of a shop you haven't tried yet.
I
Ict57
I'm in exciting wichita KS! Anybody have good suggestions for this neck of the woods?
73azbronco
Are these the ones Gas Monkey used? I was going to try that as well, even bought six of them.
Then My favorite shop said look real close before you do this, I did. Compare the thickness of metal on a standard white spoke wheel for a Ford axle, pretty beefy right, like 1/4 inch thick? The dodge wheels use far thinner material, maybe 1/8 thick, so by the time you ream out the center, the material left is very thin next to the lugnut holes, too thin. I gave the rims away...
I
Ict57
I don't watch gas monkey so maybe? Not above it just don't watch much tv now that dexter ended (poorly).
Standard ford bore is 3.5" and dodge 17s are 3" so I'll need to remove 1/4" all around.
Re risk, I'll measure the thickness tonight but they're probably 3/16 thick, certainly more so than stock 50 year old bronco wheels. I may be off (and will confirm tonight) but I'm not too concerned.
I
Ict57
I did confirm 1/8" original and 3/16" dodge. However to be fair the fords have a small rolled lip to reinforce. I'll defer to the structural engineers to compare the two and name a winner (50% more steel vs 1/8" lip).
That said, I'm not overly concerned. I can honestly say this truck will see 10x the abuse of most 'built' jeeps around here, though that's not saying I'm remotely hardcore. Just that others are not (yes, the new van maur can get pretty crazy when somebody parks on the snow bank at a 15* angle!).
I'll pester some other automotive machine shops and see what can be done. This is the look I want, though I can't justify spending $500/wheel for custom jobbers. Especially since they're pretty likely to get banged up.
1sicbronconut
I made a jig that bolted on via the lug nut holes and used a hole saw to make the hole larger. The wheels center on the studs so if it's off a little it's not a huge deal.
I
Ict57
Thanks and yeah that was my plan B, figure it may be a bit more difficult to balance but with big tires can't imagine a few grams off center will make or break. Appreciate the note, sounds like I won't be the first to do it that way if so..
Pa PITT
Stephenville TEXAS
My running Buddy did a set of 16 Dodges But he has several lathes in his shop.
.. I like that ''ISICBRONCONUT '' . THAT Was what I was thinking just center up a hole & use a hole saw.
okie4570
NW OK
Exciting Wichita? Where else can you go and see resident Canadian geese on everybody of water during the summer when it's 105*? lol ;D
rguest3
I had the center holes bored on the Dodge 17s at a machine shop. I also had a center cap from a mid 90s Full Size Bronco and they tapped the 3 holes for the retaining screws. Looked great when done. (265/70/17 Tire)
Crush
Greenbottom, WV
Here is a thought. Instead if boring the hole bigger can a press be used to push a cone shaped stretcher through the hole and open it up. You would still have the lip around the ooening and not loose any strength? Just a question
T-Bird
East TN
Same here. I Have a friend who has a machine shop that did mine for $40.00
Added some trim rings and centers I had laying around.
FlogginHarvey
Wichita
Trail worthy fab in Wichita re centers h1 wheels... He might consider another for a custom job?
You also might find some help in the kansas classic broncos facebook page?
