bottom door inner rust
brad smith
tupelo ,ms
about to tackle a job. the bottom inner of my 74 bronco door is rusted. how would i start and with what tools can i use to seperate the outer skin from the inner skin with out damaging the outer skin thanks in advance brad
pcf_mark
Does the rust reach to the outer skin? I have "rare" 66-68 doors and I wanted to save them. The driver side was rusty in the inner door but the skin was good. I cut away a 3" wide by about 16" long section of the bottom of the door (back half) and formed a new section with basic tools (hammer, dolly, vice, stretcher, patients) and welded it into place. Once I cleaned up the welds it was pretty solid.
The real trick was to use an Eastwood stretcher
https://pitstopusa.com/i-14357916-e...MIh4Xk37KN2AIVRksNCh1P-Q6JEAQYAyABEgKdpfD_BwE
I bent the section 90 degrees first then ran it through the stretcher a million times and it curved (my section included the curve at the back of the door to get a solid repair)
https://garage.eastwood.com/eastwood-chatter/channeled-bench-seat/
Pa PITT
Stephenville TEXAS
Sorry but I'd say just buy some different doors.. About 8 hours of time & you ain't done. So get a set of doors that you can control in about 4 or 5 hours. No need putting 40 hours into a door.
STalon89
It depends on how far gone it is. You can find a factory door for a few hundred bucks that you can sand and do minimal body work to. Aftermarket never fit right, but doable. Just depends how you much your free time is worth.
brad smith
brad smith
tupelo ,ms
i started this project last night. the door is in great shape except for the corner on the hinge end. gonna tackle it. i dont have nothing but time. gonna post pics later
brad smith
brad smith
tupelo ,ms
but doesnt that take the fun out of it. lol
pcf_mark
Reminder to use weld through primer on your seems / joints and a high quality two part primer on the inside when done. This way the door will not rust out once you are all done fixing it.
