Bottom door skin(inner bottom)
brad smith
tupelo ,ms
Has any one ever repaired the rust onthe bottom of a door onthe inside with a repair panel. If so could someone send me pics before, during, and complete of the job. Thanks in advance brad
Rocko1012
door repair
I too was looking at the door repair panels at Denis's, Just not sure how to attach and what to cut out based on the shape of replacement panel edges.
rydog1130
your outer door skin folds over the edge, there maybe trimming involved
Gweiner
Charlotte
Following. I have similar minor rust on door bottoms only and was thinking of buying the DC door bottom panels. Think I may just cut the rust out and try to weld some patch panels from sheet metal instead. All else fails, will bite the bullet and buy new doors...
thegreatjustino
Red Head Grease Monkey
Stockton, CA
Buy the patch panels and cut what you need out of it. Don't use the whole thing unless you have to. Leave as much OEM metal as you can.
bronkenn
Bronco Guy
Southeast Ohio
What Justin said. It is a whole lot easier to do that than to replace the whole piece. I very seldom use a whole patch panel. Ken
Rocko1012
If anyone is going to use the DC, door bottoms please post pictures of process.
