garberz
Bronco Influencer
Ok but if so I thought each spring eye used different size bolts...or are they the same? I really don't wanna do all this crap again. You can see the before pic and after pic with this bronco's springs. Like I said, there is another bronco here with them the same way
The spring eyes use the same size bolts, the shackle to frame uses a smaller bolt.
Are you using yours as an example or what?I am by no means an expert on rear springs but how are you certain yours are right?Mine work fine but now you are making me second guess my original setup.
Yes, I'm using mine as an example. And two others, all have different brand springs. Mine are Deavers, double wrap up front, center of spring at bushing level, goes towards the shackle. The other two Wildhorses springs. Same position as mine. Third one, Alcan springs. Double wrap F&R. He had these on backwards for several years, ended up digging in to his shackles on some technical trails.
I'm no expert myself. I'm going by my own experience. Someone else will eventually comment to assure you guys, or say I'm completely wrong.
Mark
