blazinchuck
- Jul 14, 2005
- 3,319
wow, if things couldnt get any worse...had a friend come by to help check. my bronco (for whatever dang reason) has a 92.5" wheel base. Doug's 76 has 93" wb. Ryan's bronco(the one im working on) has a 90.5" on the pass side!!! and a 91.5" on the dr side!!! I just dont understand, the frame looks good, no signs of wrecks. also just got another set of springs with a add-a-leaf...so they have a great arch to them and i will install them soon.only thing i can figure is something is up with the blocks. the radius arms look correct(no worn out bushings) both shackles look like they are standing straight up...i thought maybe one would be forward, and one back...but its not. also, the damn axle housing is leaking around the rear cover from factory weld area...ugh!!!
