malonejy
- Jul 21, 2001
- 1,032
I need some help from all you gurus out there. I found a leak in my brakes (at the rear axle junction) and tightened that up. It's not leaking there anymore but my brakes were still not working right so I figured I better bleed them. Here's the issue, I can bleed the rear just fine, but not the fronts. On the fronts, the fluid isn't getting pressure (barely any). In other words, I don't get any fluid coming out while the pedal is being pumped.
Does that mean my master cylinder is shot and only applying pressure to the rear brakes? Thanks.
FYI, it's an aftermarket hydroboost system, the same one Wild Horses sells. I actually replaced the master cylinder on it about 4 years ago after the master cylinder was letting air into the system.
James
James
