- Nov 3, 2003
- 49,365
Somebody recently (I think it was James Roney?) gave a good description on how the different switches work.
But with the modern valve with a single wire switch going to what was originally a two wire set up in the bronco, you simply twist the two wires from the bronco to the one wire on the switch. It’s not a one wire to one wire simple connection.
As you’re saying the lamp tests itself every time you turn the key to start. It literally lights as long as the key is in the start position though. It doesn’t flash like a blinker, it stays lit until you release the key.
To do this the ignition switch must be mounted to the dash so that it has a ground path through its body. Which means the battery has to have a body ground and the dash can’t be all painted up and powder coated or rusty. All those things get in the way of a good ground connection.
The test wire, or prove out circuit, is simply a ground for the switch in the start position only.
Beyond those basics, I literally have to study the wiring diagrams for half an hour every time I’m gonna work on one of those circuits just to make sure that I’m seeing it clearly in my head.
So you’re certainly not alone in head scratching with the brake warning light circuit.
