can anyone recommend a direct fit replacement for the below 5"x7" aftermarket brake booster? PO put discs on the front 20 years ago (ive had it for a week) and the brake pedal bottoms out when the engine is running. the pedal is rock hard when the engine is off. most of the posts ive read suggest a bad booster. ive checked for leaks and dont find any moisture or weeping seals (have not inspected the drums). ive replaced the proportioning valve (it was leaking) from a little hole in the side of the rear circuit. i currently have the plastic bleeding tool screwed into the prop valve. i clamped off the vacuum port and the brakes remain firm while running. i dont know how a faulty booster would cause this but im willing to be educated...im kinda getting frustrated and if more than one person told me shaking a dead chicken at it would help i would consider. pics...
