Brake booster push rod adjustment
jckkys
Got my '77 back from the restoration shop after a frame off. On the way home, the brakes seemed to be dragging but I got home. A short drive the next day ended with the brakes locking up. I had to crack the bleeders to get home. Research tells me the booster push rod was holding the master cylinder piston off it's seat, so it couldn't relieve the fluid pressure. Every application of the brakes built more pressure. It needed to be adjusted much shorter.
The '77 shop manual describes a push rod gauge and how to fabricate one. I don't own a machine shop and making a one use tool is a PITA. I would think such a thing would be available. The F and E series trucks all used this same system and specs. Does anyone know where to find a measuring tool or have a work around?
I'm also curious if the master cylinders for many vehicles have the same depth for the piston cup.
I gotta get one of those tools someday! But while cool, as Slowleak said you don't absolutely have to have one to make this work.
You can use a dial-caliper and it's extension piece, OR just eyeball it.
I've double-checked mine with calipers occasionally, but since the eyeballing method has worked every time, it's just more for clarification and testing to use a tool.
Leave the lines connected, unbolt the master from the booster and pull it forward. Move it back until the rod seats on the piston and see how much gap you have at the mounting flange still before it bottoms on the booster. This gap is how much you need to adjust the booster rod inward. Do it until the master touches down just before the rod touches the back of the piston and button it up. Done (usually).
If the adjustment is correct already and you do not touch the rod to piston before the master touches down on the booster, then you may actually have a defective new booster.
J
jckkys
I just shortened the booster push rod until the master cylinder easily fit flush thinking it takes real pressure to move the master cylinder piston. This job revealed a pile of other incorrectly installed parts and incorrect parts so a road test will have to wait till I fix those just to put things together. The restoration shops are geared to making pretty race cars not accurate restorations. That's no problem if you're building a Cobra kit car. But I wanted an EB that at least looks like an original Bronco, but works better.
J
jckkys
The video was good. My problem was the opposite in that I got my Bronco back with the push rod set way too long so I had to shorten it. Oddly I had installed 2 rebuilt boosters over the years and followed the instructions. So I never got to see the results of a bad install. The brakes locking up was new one.
