Preface by saying all of my manuals and Bronco books burned in a house fire a while back. Having said that, now that I got my Bronco running after three years, the break lights do not work. All the other lights work as they should. I have replace bulbs and checked grounds both on the frame and behind each light housing. I took a quick look at the brake light switch and wires are on it. It looks pretty sketchy. Plastic is cracked up and it is very loose. I will check voltage, but if it needs replaced, does anyone have a link to a writeup on swapping it out before I just start tearing crap up? Thanks
