Brake lights not working
Jbz1029
I’m having a problem with my brake lights. When the bronco is just sitting the brake lights work fine along with headlights running lights and the signals. But when I’m driving the brake lights go out but everything else is working fine. I do have a harness for a trailer that I’ve never used if would cause a problem. Does anyone know what could be the problem
Well, that’s a unusual one.
Bad ground or a bad turn signal switch maybe?
But first are you sure it’s the brake lights that are working? Are they nice and bright or do they look kind of dim like they might be working on the running light filament?
Sounds like they should be working correctly because you say they work when the other lights are on.
But I figured I’d check because I’ve seen that before when there was a bad ground at the taillight.
I’m glad you mention trailer wiring. But be more specific.
Does your bronco already have some kind of trailer wiring installed and spliced into the rear harness? Maybe one of the fixtures is failing and doesn’t work well when there is the vibration from driving.
Probably a longshot, but at this point everything’s on the table.
J
Jbz1029
I did replace the bulbs thinking the bulb or socket was bad. The socket looked fine no corrosion. It looks like the wires from the rear harness go straight into the plug for the trailer harness. The turn signal switch is was I’m going to check next all the grounds where solid and clean.
