Are you sure the bleeder said 10 foot pounds? And not inch pounds?
Admittedly, inch pounds sounds a little light, but foot pounds sounds like the ragged edge of way too tight.
Ideally marking the seat area would be best. I don't know how you could do that. Dykem you can put in the end of a swab ( not a Q tip) to cover the seat. Needs to be a thin layer. Spray dykem might also work.
You can do the same thing where your banjo fitting should be sealing. You are checking for high and low spots and complete sealing.
Thanks, sounds like 6-9 ft/lb as I look, but generally, not very tight. Small wrench just stop fluid coming out is my barometer… test the brakes and if leaks maybe a 1/8 to 1/4 turn tighter, does that sound right?
Sounds more like it.
Closer to that 1/8 turn, however, as I don’t think I’ve ever turned one and a quarter turn past tight.
Some of the cheap modern ones would probably snap off!
