chris
No more Rock Crawler
- Nov 27, 2002
- 1,893
Long story short, I took the front axle out to work on it and found a rubber brake line leaking. Figured I would replace both lines with Braided lines so I ordered 2 lines from Wildhorses for the 76-77 disc axle. I have a 71 axle that got the drum to disk conversion. The new Brake lines had larger hardline connections so I put adapters on and the caliper end was 1/16 to small for the old banjo bolt so I drilled it out. Used new copper washers and put it back together.
Bleed the front and rear lines but the brake pedal still goes to the floor and won't hold well. Figured the Master Cylinder was bad so I picked up a new one last night for my Duffs power brake unit. Bleed the lines again but still same problem, try to gravity bleed everything, still same problem.
Brakes worked before, WTH? The system acts like there is a leak, or air in the system, even if you pump the brakes it still ends up going to the floor.
Only real difference is the new brake lines. No leaks at all. Fluid flows easy and drains Master cylinder with no issues.
Id like to try replacing both of the soft lines but I need to pick them up local because of the time left before the event, anyone know what I should tell the local auto parts guy I need?
Anything else I should try?
