ntsqd
heratic car camper
3/16" OD with an .035" wall thickness is the common brake tubing set of dims. 104" wheel base, likely closer to 110" of brake line. So roughly 3.03 in^3 of brake line volume.
RA lists two different m/c bore sizes, 1-1/16" and 1-1/8"; I'm pretty sure that I was careful to order the 1-1/8"
At 1/2" of m/c piston stroke that comes out to be .497 in^3 per stroke. That makes it 6 strokes to push the fluid that started in the m/c out of the bleed screw.
What I was alluding to is that I have no way to effectively measure the volume ejected before the bubbles arrive. I use the peanut-butter bleeder to capture the ejected fluid (rather than making a mess) and to insure that no air is drawn back in during the return stroke. FWIW I load the bleed screw threads with dielectric silicone grease whenever I put a new caliper on a vehicle, no air is likely getting in on the return stroke by that means.
