brakes
golfobx
Suffolk, Va
i just did the dana 44 axle swap, now i have disc brakes up front...i have the WH booster/mc and prop valve.
i have bled the brakes 5 times with engine off, and 2 times with engine on...no bubbles noted, and i have someone pumping brakes while i am under there bleeding...i have used a pump bleeder as well...
the rear drums have been adjusted out...
with engine off, the pedal is rock hard, with engine on it goes to complete mush, and has no resistance at all...then its extremely slow to rebound back up
suggestions??
bigdaddyof4
Vincennes, IN
Bad booster cause if it was any thing else it would do it running or not is my guess.
Try unhooking the vacuum booster and see if the brakes work.
Apogee
Tangent, OR
A bad booster would typically result in a high and hard pedal, not a soft and mushy pedal, so the booster would not be my prime suspect. It sounds to me like the master cylinder may not have been properly bench-bleed, or there's still air in the system somewhere. In order to troubleshoot the issue, I would start by plugging both outlet ports on the MC and testing the pedal with the engine running. If it's still mush, then you know that you have air in the MC. If the pedal is high and firm and doesn't sink with steady pressure, then I would reconnect the rear brake circuit, bleed and reassess. If everything feels good, then add the front circuit, bleed and all should be good. If it's not, then you know it's in the front circuit somewhere since you've ruled out everything else...upside down calipers seems to be a popular one.
Chevy or Ford disc brakes?
Could be, but sounds more like a rod-adjustment issue. A bad booster would normally just not give you enough assist, but would not cause it to go all mushy or to the floor.
Usually...;D
Did you assemble all the parts? Were they all pre-assembled?
What about the brakes? Did you verify they're correct mounting of the calipers? Regarding the rear brakes, just how tight are they? Do they scuff pretty well when you spin the wheels and make it just a bit harder to turn?
G
golfobx
Suffolk, Va
yea, the scuff when i turn the rears, so they are adjusted out pretty well
i installed a new MC today, and it helped slightly, but not fully, i am wondering about the rod adjustment...can i order a new rod if there is a problem, or does that require a whole new booster?
G
golfobx
Suffolk, Va
here is an off question, wish there was a way to post a video, but it is normal for the whole brake booster to shift (move) slightly when the brake pedal is pressed as hard as possible?
G
golfobx
Suffolk, Va
Here is the pushrod. Not sure if it's adjusted correctly but this is where it was when I bought it. And this is how it currently sits.
There's no way for us to tell if it's adjusted. The only way is to either measure the corresponding recess depth in the back of the master cylinder, or screw it out far enough to actually contact the back of the piston with the master is mounted, then take just enough out of it (turn the pin back in) until there is about 1/64" of clearance/freeplay between the back of the piston and the tip of the rod.
Basically you don't want it under pressure, but you don't want any more gap than absolutely necessary. A 1/4" here equates to about 1.5" of travel at the pedal.
Then there's the other two adjustments...
The pedal-to-bracket rod needs to be a specific length.
The bracket cantilever-to-booster needs to be a specific length.
The booster-to-master rod (the one we were just talking about) needs to be the exact length needed.
But the master needs to be pumped up too. When you bench bled the master, did it ever pump up fully to the point you could no longer push in on the piston?
Can't order just the rod only. It's part of the booster. But the master has to be the type with the correct piston recess depth to work with a given booster. So that's where I'd start next. Take some quick measurements or simply slide the master on to see how much clearance you really have. Clarence...;D
Good luck.
Apogee
Tangent, OR
correct, did it for a good 15 minutes for good measure
There are two common methods of bench bleeding a master cylinder, the recirculation method and the plugged-port method. Assuming you did the recirculation method, 15 minutes doesn't mean it's fully bleed...in fact, no amount of time does. Some units will bleed in a few strokes, others will never readily bleed with that method. A quick test would be to plug both outlet ports and stroke the piston...if it strokes more than 1/8" to 3/16", then it still has air in it. If it hydraulically locks after about 1/8" plus or minus of stroke, then it is fully bleed.
That's the advantage to just bleeding it with plugged ports to begin with, you'll get positive feedback as to whether it's fully bleed or not.
moses_m
Did the swap over the holidays and had the same issue mushy peddle. Turns out I had the brake calipers on backwards and they were not bleeding correctly. Luckily we had a guy there with a 76 F15O and we compared my calipers to his. Same OEM calipers but my brakes would have to be pumped several times for them to grab. Spent a couple hours bleeding then removing master cylinder checking back brakes for adjustment and leaks. Mine was a simple error but it was head scratching for a couple hours. Before the guy arrived almost shipped booster back.
67RT
Common issue with Mopar swaps. Bleed screw must be on top of caliper when situated or it will never bleed all air out. Glad you found it.
Don't feel bad. IN HS 30 years ago I put the shoes for my 68 firebird on wrong.Front on back and back on front. It did not stop well...
G
golfobx
Suffolk, Va
I bench bled again. And it did firm up better. Still needs some work somewhere.
Luckily i had the bleeders on top, but at this point I wish it was that easy. Haha
Justafordguy
Keep in mind that they will be "on top" even if you have them reversed. It will fool you when you look at them but if the left is on the right and vise versa the bleeder will leave a little air right in the top corner of the caliper.
