Broke it.
bax
Old Member
Well looks like I broke the d44 under the red and white racer. Not that it had not been hammered on but I was stupid. I was pulling a stump
( hurricane) out to the street for trash pick up. I got to the end of the drive and made a sharp turn in reverse on dry pavement. POP, Shudder. Crap I know what that is. Got it on the lift tonight and sure enough. The pinion is missing teeth and I have carrier pieces. Broke the pinion gear and the recoil broke the carrier. All for a stump! I are smart. Anyway looks like I got some work to do. Windrock in 23 days?
fordfan
The racer makes the coolest tractor until....... I'm sorry Bax!..... The good thing is You can fix it!
NGABronco
Always Learning
N. GA now South Carolina
Pulling stumps, diving in holes and jumping mounds voids the warrenty!!!;D;D;D
englewoodcowboy
Lick Creek Restorations
Tough break bax. Somehow I know you had a big grin on your face right up to that moment... (seriously lame pun intended )
Rustytruck
Wow pulling a stump. Maybe next time cut off the 60 foot tree of the top of the stump. Pulling backwards is alway bad on the front carrier. I hope you're bearing caps survived the ordeal.
At least its at home where your set-up to do this work. Tough break.
best wishes. I hate scrambling just before an event.
Ethansdad73
Time to upgrade...!! If Pam asks I did not make said suggestion. ;)
Sent from my SM-G920P using Tapatalk
bax
bax
Old Member
Thought about it. A 60 would cost about 4K to get it where you could beat on it. Plus I would have to re valve the front shocks and it would not fly as good with the extra weight of the 60. Im in the shop tonight taking it all down.
clarrance
Build a 9" for the front. Very strong and simple.
bax
bax
Old Member
I agree. a 44/9 would be great.
