Broke outer front axle,need advice...
HOT RAM
Shenandoah Valley,VA
While wheeling in the snow I managed to break the driver side axle u-joint and then bent the ears on the outer axle.Also broke the selector hub so I will probably get WARN premiums this time.
Looking for advice and opinions on repair :
buy stock axle and u-joint
get chrome-moly axle and u-joint set for just driver side
get a chrome-moly axle for both sides (with 1-ton u-joints)
While I like the idea of upgrading things as they wear out or break,I am thinking about what will be the next weak link if I go with the chrome-moly axles/1-ton u-joints ? Will I be risking tearing out the gears ? Or will the hubs be the weaker ? I have heard of "fuses" for the hubs that will break before tearing out u-joints,gears,or axles.Any experience with these or advice/opinions ?:?
I have a pretty stock 5.0 engine with 2bbl carb,long tube headers,NP435,4.10 gearing,and running 35x14.50 Pitbull Rockers.Oh,and a Yukon Grizzly locker in the rear and open up front.
bknbronco
North Metro, MN
u can get 28 spline axles that are way stronger than stock i think and they wont break the bank. The stock stuff can be pretty weak when abused
asinor
Tulsa, OK
Warn doesn't make the fuses anymore, you might be able to find some old stock though.
Axles are realtive cheap and easy to replace compared to 3rd member parts.
Are we talking front or rear axle? At first I see U-joint and outer axle and was thinking front axle. Next we are discussing 28 spline and 3rd members, so are we doing rear axle?
Boing with the OP comments, I am going to guess it is a front axle issue...
Are you running a Dana 30 or a Dana 44? the outer axles are interchangable but not the inners. Good chance that when the U-joint went out it bent both sets of ears. So a whole shaft is probably needed.
A great cheap upgrade for the Dana 44 is full size U-joints. The short side axle from a 70's F150 often needs a hair shaved off the inner shaft to fit but a Blazer D44 shaft short side drops in good. Long side from either donor and get it shortened to Bronco size. Amazingly strong, as good as some of the low end aftermarket shafts for less money.
If it was a Dana 30 then you can only use the Bronco shafts and U-joints. Not worth chasing down upgrades as the shafts are about as strong as the gears in the diff. It is often a toss up on which will fail first.
HOT RAM
HOT RAM
copied and pasted from original post :
so...................
it is the FRONT,
Drivers side,
outer axle,
DANA 44
Get a junkyard short side axle and put it in with a new hub. Easy cheap upgrade. Probably easier and cheaper to find that shaft then one from a Bronco.
blubuckaroo
Grease Monkey
Ridgefield WA
I you need to drive the car while waiting for parts, you can pull both the inner and outer shafts, reassemble the rest and drive it. A hand ball makes a perfect sized plug to seal the axle tube.
HOT RAM
HOT RAM
Thanks,it is just for off roading.I have several other vehicles to drive.
I am pretty sure I will be upgrading the whole thing : WARN hubs,chromoly axles,heavy duty 760 u-joints.I haven't verified this yet but I have been told that WARN still has the fuses for the hubs,so that seems the best way to go to me.?:?
well,they are NOT available
so,what to do,what to do.......
I would really hate to upgrade the axles and u-joints and have something go bad in the diff
blazinchuck
One ton ujoints?? In a d44?? Now I'm confused. Get some spicer 760's and use full clips. I've found premium warns broke before standard warns. I always thought the insides were the same but I've killed 4 premiums to one standard
Sent from my DROID BIONIC using Tapatalk 2
No 1-ton U-joint without going up to a Dana 60 front end.
Stock was the tiny little 260 joint. anyone who has wheeled enough knows they are fragile. that is why the common upgrade is the 297/760 joints. This is the same thing normally used in full sized half ton trucks. Generally that is all the upgrade you will ever need. Of course you need shafts with bigger yokes to fit the larger U-joints.
HOT RAM
HOT RAM
Ordered the chrome moly axles with 760x u-joints from Tom's
and Mile Marker stainless supreme hubs from Jeff's (they just look better and look different from what everyone else runs)
Time will tell if I made the right choice
bad 68
Northest Washington
I wouldn't worry about tougher axle Assemblies out living your 44 diff. Those 760 joints ain't that tough. They will break before a quality ring gear gives it up.
I snapped the cross on a brand new 760 that was spot welded in. True Trac up front was all. And the front tires were strait ahead.
Not trying to diss on your purchase. You may have great luck.
HOT RAM
HOT RAM
I usually do have great luck !! ;D
as hard as I have been on stock stuff past five years and just now broke a u-joint (made lots of newbie driving mistakes) I should have lots of life in the new stuff
