76 bumblebee
- Joined
- Sep 23, 2013
- Messages
- 43
ok I have searched and the damn search button and google don't like me. what I have is a 351W with a C-4 transmission with a dana 20 tcase in a 76 bronco. I took the transmission and transfercase out and found that one of the heads of the flexplate bolts was broke off. it didn't break off flush. there is a little less than 1/4" remaining out. also the other 5 bolts had the last 3-4 threads stripped at the end of the bolt and were hard to remove all the way out. I tried an easy out tool that fit over the remain bolt with no success.
two questions:
1: looking for an opinion of welding a nut to the remain part of the bolt. I understand about trying to weld on the end of the crankshaft. if grounding to the nut and not to the block would that be okay.
2: what would be the issues of just leaving that one broken bolt and 5 new flexplate bolts.
thanks,
two questions:
thanks,
