broken flexplate bolt
76 bumblebee
ok I have searched and the damn search button and google don't like me. what I have is a 351W with a C-4 transmission with a dana 20 tcase in a 76 bronco. I took the transmission and transfercase out and found that one of the heads of the flexplate bolts was broke off. it didn't break off flush. there is a little less than 1/4" remaining out. also the other 5 bolts had the last 3-4 threads stripped at the end of the bolt and were hard to remove all the way out. I tried an easy out tool that fit over the remain bolt with no success.
two questions:
1: looking for an opinion of welding a nut to the remain part of the bolt. I understand about trying to weld on the end of the crankshaft. if grounding to the nut and not to the block would that be okay.
2: what would be the issues of just leaving that one broken bolt and 5 new flexplate bolts.
thanks,
I am thinking that someone used flywheel bolts on your flexplate. How long is the bolt? 7/8" or 1"? If all the bolts are damaged something is really wrong. Was the bolt head anywhere to be found? It may have broken and whoever put the engine in just went F-it. Or did the bolt head pop off?
http://www.youtube.com/watch?v=jzCMoDDSF6o at 9:55
strokers
I don't see a issue with welding a nut onto it . it won't take long to fill in the Nut so not much heat transfer. I would be more worried about the seal.
76 bumblebee
76 bumblebee
The head of the bolt was nowhere to be found. It had been broke for a while. The bolts that came out were definitely too long. I took apart another transmission I had at the house and the bolts holding that flexplate were much shorter. Thanks for the idea of using the flexplate as the ground. I was wondering how to ground the nut so the current wasn't going thru the block.
76 bumblebee
76 bumblebee
Thanks for the help. The bolts that were used were definitely too long. I pulled another engine and transmission apart at my house an ur had much shorter bolts (with one of them also broke off). I was wondering how to ground the nut so the current wouldn't be going through the block. Thanks for the flexplate idea.
