It depends how close you are to the threads. How much "meat" is left? It may still work if you're gentle but if it hasn't budged with the regular extractors you may have the same outcome. If you do decide to try the square extractor, try and find one that just fits the hole. Tedious job for sure. Just be patient.Thanks guys - a little bummed at the moment.
So do you think I should get a couple larger square extractors or has extraction time passed?
Or is it drill/ream/pick time?
Won't get at it today as I have to work.
Same thoughts as when you were starting: use the BEST extractor - not necessarily the most-convenient to grabThoughts on proceeding?
You tell us....or has extraction time passed?
I suspect broken engine mounts are a big part of why the Aluminum fatigues & cracks.Sometimes the aluminum ones failed from being knocked around during some kind of work on the engine.
You should try to find the supplier of the stainless one I linked above - it's outstanding, and I've bought it on Amazon as low as $14. You can see it at the far Right of this pic:We were trying to sell the stronger steel replacements, only to find out we were receiving aluminum ones in the new packages.
That only applies when both metals are exposed to the same electrolytic solution (i.e.; water or water with any salt or acid in it, including rain which picks up CO2 as it falls creating weak carbolic acid) as in a battery or on a boat. Coolant is supposed to inhibit that (if it's maintained properly) in the coolant system, but this is just oil - it can't create galvanic corrosion....I wonder if “dissimilar metals“ has anything to do with the failures.
How many blocks have you seen with damage to that hole from a steel extension getting bent? Even the steel ones will break first because they're necked-down so abruptly, and the external threads make them easy to crack, too.I always assumed ... that it snaps instead of potentially damaging the block.
Any of the big ones should.Does that one send the right kind of signal for the original oil pressure gauge?
I was thinking about this as well. My plan was to eventually carefully vacuum it out with some vacuum hose and prime the engine. I see Melling has these. Do stock 1973 302s have 1/4″ hex shaft or 5/16″ hex shaft?I would suggest using an oil pump priming tool after clearing the port to push any debris out.
Certainly, I over did itI think you really OVER-did the cleanup. I'd have spun the pump shaft for a second just to get a few drips of oil out of the threads - not a stream. I'm saying: it's good.
(click this text)
Next time the extension is out, I will likely go that way - thanks.Or if you ever want to install a aftermarket gauge alongside the stock gauge:
Scott Drake C2OZ-9B339-DP Scott Drake Oil Pressure Sending Extensions | Summit Racing
Free Shipping - Scott Drake Oil Pressure Sending Extensions with qualifying orders of $109. Shop Fittings and Adapters at Summit Racing.www.summitracing.com
I wanted to go this route, however the one I looked at was 1/8 NPT and the hole in my block is 1/4 NPT.I run the ps-17 sender that eliminates the extension. That's on a couple 351w. It threads directly into the block with a metric socket
Best of luck!Timely. I just noticed a major oil drip under the Bronco and traced it to the oil pressure extension. The best price I could find was on eBay for a steel one. I might end up replacing the sending unit as well.
