sp71eb
Hello, I was wondering if anyone else has had this problem. I did some google searching and founds lots of suggestions from people but no actual solid solutions. My rig runs but if you try to take any timing out of it under 20 adv it wants to die. It smells pretty rich also. I was in a hurry to get home after work today so I didn't dig into it too much. I did check for vacuum leaks and didn't find any obvious ones. And yes I did have the spout connector out. It seemed to run best around 25 to 30 adv. Some online answers were. Incorrect firing order (the engine has a b303 cam so I'm pretty sure its 351 firing order). Some said too much flow from pcv that is acting like a vacuum leak. Some said bad dizzy. Any help would be greatly appreciated.
