alindao1991
- Mar 30, 2016
- 4
76 bronco, 302 v8, holley truck avenger off road carb
bronco sits unused for extended periods of time
brand new battery
before last april, never had a problem..
then last april, engine cranked but wouldnt turn over unless i sprayed starter fluid in carb. fuel pump works because gas poured out of fuel line when i disconnected from carb and pressed down on pedal. also put some new gas in tank as well. gave up because of other commitments
tried again last week. engine cranked but wouldnt turn over this time even after spraying engine stater fluid in carb. so, i dont know what the problem could be.
any suggestions are welcome. not much to go on, but any ideas would help. thanks!
brand new battery
