The caster looked high to me, but not way out of line.
Camber Left 1.1 degrees
Camber Right 1.0 degrees
Caster Left 4.1 degrees
Caster Right 4.4 degrees
Toe .07 in
Cross Camber 0
Cross Caster -0.3 degrees
Total Toe 0.14in
Don't worry about too much caster here. You never know when you might decide to add more lift or larger tires or quicker steering. And this probably makes you the first person here to post up caster specs that were actually at or above what they're supposed to be, without other modifications being needed!!! Congratulations.
So, your caster is not only nothing to worry about, it's PP (practically perfect) for power steering. Manual steering might feel a bit harder to steer, but still useable.
Camber is right to spec, though a bit more than I like personally. Not because of handling issues, but higher positive camber specs tend to contribute to quicker outside tire wear. So again, PP.
Toe-in seems a bit high maybe? Maybe not? Wait to hear what the others say, but .14" is just over an eighth of an inch. Probably not needed with 31's, but like the rest or your readings, certainly not excessive. Probably will work well, but, in cahoots with the camber, will contribute to outside wear on the tires. Once again, PP.
Ahh, the relief...
Now get out there and drive it and see what happens. Crossing a bunch of fingers here, but after all that, it's just GOTTA' work!
Good luck.
