- Nov 29, 2010
- 634
New to me bronco, running very rich, exhaust wreaks of gas, won’t idle. Purchased the bronco a few weeks ago, I’ll do my best to tell you what I know. Stock 289, points, 2-barrel holley manual choke with 1” spacer. I replaced the points, capacitor, plugs, wires, rebuilt carb, just last week. After changing everything, it still runs rich, doesn’t want to idle below 1000 rpm’s, it does idle at about 1500, and revs fine. I don’t know timing, it looks like there is no harmonic balancer. I’ve messed with timing and timing light, ended up back at original timing. I’ve set the air fuel at 1/2 turn, still runs rich. All vacuum ports are plugged. Manual choke is wide open. It starts right up, seemingly runs good, won’t idle, just dies. I’ve adjusted idle up and down, can’t get it to sell below 1500 without dying. Starts right back up. New fuel filter shows new gas(clean) is running into carb. Stock exhaust manifolds, small stock exhaust.
