Well, hopefully I will have mine rig back together by then. I worked on my wiring more yesterday. I have loomed the body harness inside the cab and under the hood. I only have a few more connections left to make and I hope I can get those done today. I have already figured out what goes where and what wires attach to what. I just have to make the connections (turn signals and side markers on the front). Install fusable link to the main power wire for the harness......Install ground cables (body to frame, block to frame...) And the wiring will be done.
After that I need to install O2 sensors, distributor, fuel lines, power steering pump, serp. belt, radiator hoses, booster bracket, hydroboost unit, and plum power steering and hydroboost.
That should be about it.
