- Joined
- Jul 31, 2001
- Messages
- 8,896
Getting to 90mph and stopping quickly from 90mph is relatively easy. (I just did it 2 days ago on my first "romp on it test drive" with a bunch of new parts). But I've been able to do this literally for decades.
The hardest part is building the rest of your Bronco around those 2 goals- getting there quickly and stopping quickly.
Suspension, steering and handling are much "harder to get right". Broncos will never handle like a "new truck". You know why??? A new Ford F150 has had 50 years of suspension, strg, and handling improvements to make it do what it does... AND it has some very obvious differences than a Bronco. Looooonger WB, wider track width (a bunch) and 50 years of updates.![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
IF you have the funds to build several prototypes of Broncos to dial in your new truck to ride like the $300K Bronco you were comparing it to then you will be as close as you can get.
Bolting on parts like Bilsteins, or an antisway bar, or a new PS box ain't gonna do it. Yes, it will make your Bronco handle pretty decent at 70, but 90 is a whole nuther ball game. Try changing lanes "quickly" at 85mph in a Bronco... lol... good luck!
I've driven my Bronco for close to 300K. Travelled for 6 weeks at a time in it. Driven for 16 hrs straight to fishing holes at 65-70 mph...does fine. ALL upgraded over stock stuff like shocks, etc. 90mph ain't coming easy to an "updated" Bronco unless you design in dozens of little suspension upgrades, handling upgrades (try going around a sharp highway corner at 85mph in a Bronco)...
The $300K Gateway Bronco has dozens if not a hundred little upgrades that allows it do what it does. A "new truck" has had a hundreds if not a thousand...
I cruise at 70-75 for hours at a time in mine. It sits on 40"s, it has an extended WB, it has ORI's on each corner and sits on the equiv of 2.5" suspension lift. I rock crawl with it. It has a 460SBF with a 6r80. I'll never be able to use all the power on the street... off road yes-easy, but not on the street. I shifted out of 3rd at 90 3 days ago and I won't do it again...
So, my .02. Look past Bilsteins and new bushings if you want to cruise at 85mph plus.
