bronco will crank but goes dead
gabronco74
it will start but dies right after. i cleaned the points and the carb. but no change. any suggestions?
pcf_mark
How long does it run?
What engine/carb/ignition?
Is there fuel coming out of the squirters in the carb? Do you have a working choke?
If you have something wired funky you may only have 12V at the coil in the crank and not in the run position. With the key in the run position do you have 12v at the + side of the coil?
Slednut10
Guru? That's funny!
Does the Bronco have an aftermarket wiring harness that uses a ballast resistor?
This used to be a common problem on older Chrysler products. Vehicle will die as soon as the key is returned to the run position if the resistor is defective.
G
gabronco74
It has a early 70's 351w with a holly 650 carb. /stock ignition. it has good fuel flow out of the squirters in the carb. The choke does not work. I drove it to town the other day, ran fine until i was on my way home. it started cutting out, i cleaned the points and carb. It cranks, but goes dead right after (patting the gas does not help). I do not have a volt meter, any way to check the coil?
73azbronco
More history please. Is this a new to you bronco, has it sat long, did you change gas, change fuel filter? Did it ever run fine for longer than you mentioned?
Confirm better than 12 plus volts at battery.
Give this a quick shot. Pull the small Brown wire off of the right hand small stud on the starter relay. If the engine won't fire at all now, you know your main ignition circuit has gone bad. Could be anything from the ignition switch, to the resistor wire, to the connector at the firewall, or several other things.
If you turn the key to RUN and check the voltage at the positive side of the coil like pcf_mark said and let us know what you find.
