There is a repeated theme I see on this forum. That is "anything worth doing is worth over doing". I like a stock or near stock appearance in the engine compartment. I've done that with my 351W. No way to do that with a 300, FE, diesel or Y-block. I'm not reverting to a chrome plated after market collection of parts including headers either. The 351 works well but I think a little more grunt may help in some situations. The 3.85 crank wouldn't cost much more than a normal short block rebuild. I'm only considering it in the event the short block needs rebuilding.
The drive train has suffered no breakage or unusual wear with the 351, C4, 28 spline 9" axle, 3.50 gears, and 31s for at least 25 yrs. This combination works very well. I am interested in keeping things quiet and want to know about how to keep the valve train quiet. The few engines I've seen with roller tip or full roller rockers didn't seem to be unusually noisy, but they had headers and loud exhaust. Comp Cams said my very mild cam won't make noise regardless of rocker type. This needs to be verified.
My point about the 534 was, a real truck engine is not a high revving peaky performance engine. By the way, they are derived from the Lincoln 462 Y-block. They are not FEs. Moving heavy trucks for hundreds of thousands of miles takes a flexible power band. Unfortunately we just can't get past the hot rod mentality here. Too bad since EBs make lousy and dangerous hot rods.
