The idea is maximum torque at about 2200 RPM with max HP at around 4400. That's a broad power band that idles at 500 RPM and pulls hard at 1500. The new cam has more lift and about the same duration as the Lightning cam. The 4 degree advance should help the low RPM torque. It, as I said, is very close in specs to the Lightning, 1969 Mustang, and Explorer cams. All these are mild easy to live with cams.
Today I talked to local engine builders and all agree the roller rockers with this cam won't make any noise, as I suspected. They also agree a 9.2-9.4 to 1 compression ratio with regular gas is about right.
If you want a 10 sec. 1/4 mi. EB, go for it. There are an infinite number of better places to start.
I can appreciate what you are going for here but to avoid tuning issues and not maximizing torque available I agree that you would need parts to match and complement each other. Think about cubic inches. Think about airflow and a 351 built right may match up better with the parts you want to use and give you a reliable torquey Engine at lower cost
I loved my 300 straight 6 from high school as well and my goal was a stock looking stock sounding 347 that has low end TORQUE.
On roller rockers. Scorpions fit under stock power by Ford valve covers with massaging of baffles. Some cam profiles can be noisy.
I love my 4100 but even on the 347 I used the 1.12. Throttle response is great and many who ride in it feel almost as good as EFI. There is a 1.23 version but they are like the holy grail of 4100s. On a stroked 351 the 1.08 may cost you torque and primary cruise metering may be an issue that could cost you economy. Consider the 1.12 at a minimum and spend the time tuning it right.
Headers help with flow. Drawbacks noise and heat. I'm using BC shorty's. I considered high flow cast iron but found they were even restrictive to mild 302s. Based on those cubic inches they may choke power even at 3500 rpm
On your heads make sure springs are upgraded to handle the roller cam profile you choose. Check size of chamber. I'm running 9.6:1 but never run less than 91 octane since it's a carbed engine with non computer controlled timing.
On the cam you will have low end torque but I think you can maintain a great amount of low end torque and gain midrange with a little more lift and duration.
Watch the LSA. Higher LSA will increase idle quality but it will cost midrange torque. I am running the 35-349 that timmy has. For a 512 lift cam in a 347 when you hear my truck idle you would think its a Stock 302. Look at the engine it and you would think its stock 302
My advice find some desktop dyno software maybe comp online one and see what your choices yield. Then bring cubic inches down to 351 and you may see the stroker may not add much value using small heads, cam, cast iron manifolds.
It's your truck and your engine. All your choices. I made many compromises on my 347 that brought it from a 425 hp engine to probably a 375hp engine but with great torque, great idle quality, vacuum brakes, and a very stock looking engine bay. I think what many are trying to say is match the parts so the stroker cubic inches are adding value to the equation.
Good luck!
Sent from my SM-G960U using Tapatalk
