C-4 Auto - Third Gear Starts
74bronc
My C-4 shifting got all funky on my on the way home from work today. First, the 2-3 shift was way late. Then, it started not shifting back down into first at stop lights and tried to take off in third gear. Every once in awhile, it would start out in first, then it would shift almost instantly into third, almost skipping second. This is my daily driver, so I have can't have it down for long and worse yet, I don't want to get stranded.
Any ideas? Howie? I am thinking something caught in the governor? or valve body? I already checked the vacuum line and it is ok. I will check it closer once it cools down
RT
I'm going through the same thing right now. I had to have my tranny rebuilt after I got lazy and took it to a lube shop to change the oil.
The shop that did the rebuild is going to change the governor because after the rebuild it's still acting up. Hopefully this fixes it for me.
The governor is the only thing they think would cause our problem.
I got my fingers crossed.. :)
Good luck
BwoncoHowie
C-4 Wizard
Valves dont usually stick unless something inside the trans is generating particles. I hope this isnt the case for yours. 74bronc, you may have a combination of several valves sticking. Most likely the governor and or the shift valves. I would try pulling the pan first to check for particles. If you have a pile in there larger than a dime, chances are you will need to go into the trans to see what happened. Worn out planetary gears, bushings, and thrust washers all shed a lot of ferrous metal when they begin to fail. Even a failing torque converter will generate metal that causes problems with the valves.
If you have just a few stray particles, which would be considered normal, then you might be able to get by with a valve body and governor valve cleaning. It also helps to make sure that all the factory screens are in place. There is one thimble screen under the valve body that rests in the pump exhaust port, and another smaller screen that sits in the governor intake passage. Making sure that these screens are clean and properly in place will keep the stray particles out of the valve assemblies. It also helps a great deal to put a magnet in the pan sump, carefully placed so it doesnt interfere with the filter pick-up pipe.
If your rotating assemblies are worn and ailing, it would be a matter of time before the valves started sticking again even after a thorough cleaning. Good luck with it.~bh
Governor is my first choice
Next is the valve body
That's about all it could be.
74bronc
74bronc
I drove it again last night and it seemed better than earlier in the day. It has been awhile since I changed the fluid, so I am going to drop the pan tonight or tommorrow and see what I find inside (if anything). The trans was rebuilt less than 10K ago, so I am hoping it doesn't need any internal work.
I also have an external filter kit that I am going to install. Thanks for the advice and help. I'll post what I find out.
74bronc
74bronc
So, is there any way to clean the governor without dismantling the tranny? I am planning to drop the pan and replace the filter and fluid tommorrow afternoon. Going to replace the shift lever seal and clean the valve body while I am in there. Anything else I should do?
Are additives to free up sticky valves a no no in auto transmissions? I have used the conditioner before without any problems in 4L60E trannies but never in my C-4. I don't plan to use the "seal swelling" stop leak stuff but rather a conditioner. Ideas?
airman
Try to think really hard about this. Can whatever is doing this be related to the vibration you have been having?.
If you are going to change fluid I am a big fan of the guys that pump it out through the cooler lines and change all of the fluid and not just whats in the pan. It costs more but you can usually look at whats coming out.
Jeff in AZ
74bronc
74bronc
Jeff in AZ
I don't think so because I have had the vibration all summer but this funky shifting just started the day before yesterday. It worked great on the way to work then something was jacked up when I was coming home.
The fluid isn't burned in any way but I think I am going to change it just because I haven't changed it in about 2.5 years. We'll see what happens. Really I just want to see if there is any crap in the pan.
74bronc
74bronc
update!
I dropped the pan last night. There was nothing inside the pan except some very fine metal shavings and a little blackness. Since this is the first time the trans fluid has been changed since the rebuild, I don't think that is too bad. I swapped out the valve body for my other valve body with the shift kit in it. Cleaned the little wire screen. Installed a new filter kit and put in new fluid. After driving it, i only got 1 3rd gear start out of about 7 stop signs. When I hit the gas to go, just for a split second it seems like it stays in 3rd and then it immediately drops down into 1st. It isn't happening as much as it was so I will drive it for awhile and see what happens.
BwoncoHowie
C-4 Wizard
74bronc said:
update!
It sounds more and more like the Gov. valves. Did you put a magnet in the pan? It may correct itself by driving it. Should you find it necessary to clean the governor assembly, make sure it has a clean Governor screen in place.
74bronc
74bronc
it didn't have a magnet in the pan and yes I did install one. I am thinking it is the governor valves as well. I drove it around yesterday some and it didn't try to start in 3rd at all. I'll give it some time.
ca1a73
I wonder if i have the same problem. Maybe this is why my bronco is so slowwwwwwwwww off the start. I thought it was just because of the 3:50 gears with 33" tires. But perhaps i am also starting in 3rd gear. I think i need a tach. I should be able to tell then, correct?
Bart
Buffalo Gap, Texas
Have you checked the vacuum modular on the side of the transmission? It controls the shifting. If the diaphram goes out then ???????? I know that if the diphram goes out you'll suck atf into the intake and there should be white smoke out of the exhaust. Check for a colapsed vacuum hose.
ca1a73
No white smoke out of the exhaust, so i guess thats a good thing. I was going to replace the module anyway, seeing its pretty chesp. See if that helps. Would a green stripe be ok? anyone else have any thoughts or ideas?
