RT
- Sep 29, 2003
- 1,030
OK guys , got another backwords issue.
in the cold mornings the c-4 has been slow to go into gear lately,( about 2-3 seconds) but once the first shift into reverse happens, then into drive ( same delay ) everything works fine. Firm shifts and no delays for the rest of the day.
Changed the fluid, all looked well. Levels always been good when hot.
Just for S&G Tranny guy suggested to check the level engine off after the end of the day and check again in the morning to note the difference. Noted the level will show overfull in the morning.
Hah! in the morning the dipstick was dry ! fired up the engine , still dry , added a pint now overfull!
drove around and checked it when hot and shows overfull. by about a inch.
Parked it for a few hours , checked it with engine off and the dipstick was dry again.
Checked the transfer case, doesn't seem to be filling it . but the dipstick should still show low when hot if that were the case.
the cold low level would explain the delay in the morning , but if I add more to show full when cold it seems it would puke out when it gets hot
Got the tranny guy stumped , so how about you guys ?
Advise me 'O keepers of the wisdom and all things Bronco ;D
