C-4 Tranny Question
RustyNutz
Coos Bay
On my 73 Bronco I just got I have noticed that the tranny shifts from 1st to 2nd extremely fast. From a dead stop, just at normal acceleration it will shift within the first 50-75 feet with a speed of only 5-10 mph. Second to 3rd seems about right after that. Could this be the modulator, I see they are not very expensive. If it is the modulator does anybody know the correct one for a 73 Bronco with C-4, all the listings note a colored stripe on the body but nine is really dirty.
Also there are 2 lines going to the modulator, where should each line connect to the engine, for instance Carb, manifold. Thie engine has a Edlebrock carb & manifold by the way.
TIA
Rusty.
74bronc
This seems to be a common problem on the EB c-4 for some reason. I would get an adjustable modulator and start playing with the adjustments. I had the exact problem as you and I started adjusting my regulator and now have it where I like it. I was taking my 4 yr old for a ride in it last night and I was barking the tires when shifting into second gear and she was beside herself with laughter. She thought it was the funniest thing in the world :)
72_EB
66to77
Get yourself a green stripe modulator. Napa has them. Ditch that two port one if you have one. The green stripe will have only one port. Use straight manifold vacuum.
Shifting will be earlier under light acceleration and later under hard acceleration. Adjust to your liking, but I don't recommend going past 3 full turns off what you get out of the box. Have fun.
72_EB
66to77
***Past three full turn one way or the other. Oh, you'll have to play with what is speed up the shift (in or out). I can never remember, always just figure it out when I'm doing it. Maybe someone will chime in.
